I just installed AutoCadLt2021 and I can not figure out how to make my tool bar save the Measure-Distance command. When I change it to distance and close out and the re-open autocad the toolbars shows the Quick command. I tried going to Tools-Workspace-Save As Current but that didn't work. Is there a way to save the toolbar so that the distance command is saved?
Thank you
Measure - Quick
Measure-Distance
When I open autocad the Measure-Quick option is defaulted. I can change it to Measure-Distance but I can't figure out how to save it to my toolbar. When I close acad and reopen it, it defaults back to the measure-quick command. I would like it to open with measure-distance.
It only remembers your sub-choice while in the same session: closing/restarting the program resets it. That is by design.
Why don't you just add DIST command to the QAT bar, use CUI command to drag and drop it there https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Au...
