AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Disappearing text
5 REPLIES 5
phas50
380 Views, 5 Replies
Disappearing text
I have two drawings in model space, both have text, when I put them in my title block's view port the text is not visible. I have been having this problem recently. I see my text in model space but not in paper space. Is there something wrong with my software? I am using AutoCad LT 2017.
Peter
5 REPLIES 5
pendean
in reply to: phas50
phas50
in reply to: pendean
I will try that. I would be willing to show the drawing to an expert if
that does not work. It may be that I am missing something.
pendean
in reply to: phas50
You can post the DWG here anytime if you need to.
phas50
I changed the annotative scale and it worked, now here is where it got interesting (proof that the eleventh dimension exist) every time I click on the text it shows a bigger text attached to the original. It's like a big shadow of the original text which is set to 10".
Peter
pendean
in reply to: phas50
Turn off SHOW ANNOTATIVE OBJECTS, it's the three-pronged icon with a small circle in the upper right of it next to your annotative scale on the bottom screen toolbar. Command name is ANNOALLVISIBLE, look it up in Help.
Forma Design Contest
Technology Administrators
