AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Dimensions and annotation scaling
11 REPLIES 11
Message 1 of 12
480 Views, 11 Replies
Is there a trick to scaling your dimensions and annotations? My CAD is set up to do this but when I change the annotation scale in the current view from the drop down menu the scales do not change.
11 REPLIES 11
Message 2 of 12
john.vellek
Hi @Anonymous,
Do you have the variable ANNOALLVISIBLE set to 1?  That should display the changes.
You are welcome to attach one of your sample files for me to examine to see if there is anything else to try.
John Vellek
Message 3 of 12
cadffm
Your objects dont have the property to shop up with that (other) scale and your system is set to annoallvisible=1.
Attach the new scale to your objects with command OBJECTSCALE
Sebastian
Message 4 of 12
ara_neresesian
HI
TO ADD AUTOMATICALLY NEW SCALE TO ANNOTATION DIM YOU MUST TURN ON THIS ICON OR TYPE
"ANNOAUTOSCALE" AND THEN 4
GOOD LUCK
AND IF ITS OK
ACCEPET  MY SLOUAOUTION .
Message 5 of 12
in reply to: john.vellek
Hi John. ANNOALLVISIBLE is set to 1. Attached is a screen shot. You will see the box on the left was set to 1/2" scale (scale not shown), the box on the right was set to 1/4" but the scaling appears the same.
Message 6 of 12
in reply to: ara_neresesian
Thanks, I have checked this, it is set to 4 but does not work.
Message 7 of 12
in reply to: cadffm
Thanks. When I type OBJECTSCALE it asks to "select annotative objects", I am not sure what to select.
Message 8 of 12
pendean
>>>...I am not sure what to select...<<<
Your dimensions and annotations perhaps, the topic of your query?
Message 9 of 12
in reply to: pendean
I did do that, a box pops up and says "no annotative objects in the selection set."
I tried selecting a dimension and an annotation, should I be selecting something else?
Message 10 of 12
cadffm
It sounds your dimensions are not annotative objects
Select dimension
Set annotative property to true/yes/on.. (i dont know the right value word)
Now you can give them scales with command objectscale.
For new dimension set the annotative property in your dimensionstyle..
Please read the help and test also all other commands /variables
For testing&lerning is annoallvisible=0 the best way.
Have fun the next month..
Sebastian
Message 11 of 12
pendean
Are your text styles and dimension styles actually annotative?
Start STYLE and DIMSTYLE command to find out, that's a setting you must activate deliberately, it's not going to ever happen on its own.
Read more about the topic of annotative text in HELP, I'll get you started here https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-u...
And here is a quick online video https://www.youtube.com/watch?v=JiKJXON8lpo
Message 12 of 12
john.vellek
HI @Anonymous,
Can you attach a sample drawing that contains your annotation and dimensions? I happy to take a look at how they have been implemented and will make suggestions on how to make this work properly for you.
John Vellek
Forma Design Contest
Technology Administrators
