Dimension Automatically Rotates
joeroscia
Message 1 of 10
joeroscia
I must be missing a setting somewhere which causes a dimension to automatically rotates if I move a grip of one of the extension lines.  The 3.50' dimension needs to be parallel to the line with "SD" in it (see below).  Is there a setting I can change so this doesn't happen?
Replies (9)
Message 2 of 10
Brock_Olly
You can disassociate a dimension so it isn't 'bound' to any lines by selecting the dimensions you want and typing 'DIMDIS' or 'DIMDISASSOCIATE'
The 'DIMASSOC' system variable set to '1' makes all new dimensions automatically unassociative.
https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2022/ENU/Au...
Message 3 of 10
joeroscia
Thanks for the response but no luck.  The dimension continues to rotate when I apply those commands....
Message 4 of 10
Brock_Olly
When you click the dimension what is 'Associative' set to?
If it's 'no' it should no longer move
Message 5 of 10
joeroscia
It is set to "no."
Message 6 of 10
Brock_Olly
Could you share the dwg or a part of it so we can have a look?
Message 7 of 10
pendean
Community Legend
Community Legend
Greetings @joeroscia
Moving grips has consequences: in your screenshot, the dimline now aligns with the two points I highlighted, which tells me you opted for the incorrect "dim" command to use here.
Re-dimension using this command correctly instead (see LINK from HELP), then you can move grips after the fact anywhere you want without moving the dimline's original angle https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2022/ENU/AutoC...
Message 8 of 10
joeroscia
Here you go...
Message 9 of 10
Brock_Olly
@pendean is right, I was misunderstanding your question
You should for this case indeed use the 'dimrotated' command.
Note though that you are not giving the length of the yellow line in this case.
Message 10 of 10
joeroscia
Brillant!  Thank you both!
