We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
dashed linetype ends with a space
mbracciahubbard
mbracciahubbard
I am having an issue with non-continuous linetypes. I have autoCAD LT and there seems to be a setting off that is preventing my lines from "ending" with a solid line. so my dashed line starts with the beginning of a dash, but depending on the length it sometimes ends in the middle of a "space". i've attached a screen shot. i'm not sure how to make it so that it always ends my lines with solid portion of the line.Screenshot 2024-05-08 160437.png
Patchy
Don't think you can fix that, LT or full version.
mbracciahubbard
Really? I've never had this issue OR noticed this situation at any other point in my career. I was hoping it was just a setting that my new company had set.
atGK8NU
https://forums.autodesk.com/t5/autocad-forum/end-termination-of-dashed-lines/m-p/12672462?search-act...
Seems like you and the author of this forum have the same problem. Try reading through it and attempting the suggestions there.
Specifically, try turning Hardware Acceleration off in the GRAPHICSCONFIG command and see if that helps.
mbracciahubbard
BOOM!
excellent! I turned it off and the problem was solved instantly. I actually turned it back on and set it to "basic" instead of "advanced" because the stuttering was really annoying me. But it still works! Thank you!
