AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
cursor lags using 2011 using Windows 10
3 REPLIES 3
258 Views, 3 Replies
Any idea how to remedy this issue?
3 REPLIES 3
was it working before? if so what changed?
2011 is not compatible with windows 10 it will never be
search this forum to see if anyone else is having this problem
pendean
Explore these options https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Cursor...
These folks have free tips and a package to sell you if it turns out to be an LT2011 in Win10 issue, a combo no one at Autodesk or Microsoft will ever fix http://www.longbowsoftware.com
jayhar
Do one or more of the following:
1, Turn off grid snap by pressing the F9 key or by typing SNAPMODE on the command line in AutoCAD and setting the value to 0 (zero).
2, Enter UCSDETECT in AutoCAD and set it to 0 (zero).
3, Install the latest updates for AutoCAD
4, Install the latest driver for your graphics card
5, Enter the GRAPHICSCONFIG command to verify that AutoCAD is using the correct graphics card. If it is not, double-check that your monitor is connected to the correct video port on your computer and/or set AutoCAD to use the high-performance card in the NVIDIA or AMD control panel
6, Perform a zoom extent and check for any unwanted content, then delete it.
7, Set HPMAXLINES to 10,000
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Technology Administrators
