AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Bottom bar shifting
6 REPLIES 6
2085 Views, 6 Replies
Bottom bar shifting
The bottom bar of my screen keeps shifting in its alignment. In other words, the tabs will be aligned with the tools and then the tabs will just jump up and no longer be aligned. This means that my screen jumps and falls constantly and it is very annoying. I have attached a document that shows the two conditions.
Any thoughts?
Lisa
6 REPLIES 6
Paul_Gander
I don't know what causes it to keep jumping but I found that right clicking on a layout tab and selecting 'dock above status bar' will stop it moving.
cadffm
in reply to: Paul_Gander
If you have trouble with the autowrap feature, you can disable it by set off STATUSBARAUTOWRAP
Sebastian
in reply to: cadffm
Unfortunately that is not a setting in LT.
cadffm
You are right and the list of covered versions are wrong in the AKN page.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Status...
I will send a feedback to Adesk with this info, thx.
Sebastian
pendean
jayhar
1, Ensure your graphics card and driver version are certified for the version of AutoCAD and operating system you're using.
2, Right-click the Model layout tab and choose "Dock above Status Bar."
3, Maximize the AutoCAD program window to full screen.
4, Do not maximize the AutoCAD program window but move its window borders to the edges of your screen.
5, Remove Coordinates from the status bar.
6, Remove icons from the status bar until it stops shifting.
7, Turn the STATUSBARAUTOWRAP variable to OFF
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Forma Design Contest
Technology Administrators
