was it working before? if so what changed?
2011 is not compatible with windows 10 it will never be
search this forum to see if anyone else is having this problem
Do one or more of the following:
1, Turn off grid snap by pressing the F9 key or by typing SNAPMODE on the command line in AutoCAD and setting the value to 0 (zero).
2, Enter UCSDETECT in AutoCAD and set it to 0 (zero).
3, Install the latest updates for AutoCAD
4, Install the latest driver for your graphics card
5, Enter the GRAPHICSCONFIG command to verify that AutoCAD is using the correct graphics card. If it is not, double-check that your monitor is connected to the correct video port on your computer and/or set AutoCAD to use the high-performance card in the NVIDIA or AMD control panel
6, Perform a zoom extent and check for any unwanted content, then delete it.
7, Set HPMAXLINES to 10,000
