AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Curious text behaviour - capitols and cant change with Caps lock
5 REPLIES 5
JamesPowell7164
470 Views, 5 Replies
Hi Guys @pendean
I am running AutoCAD LT 2022 version S.74.0.0 AutoCAD LT 2022.0.1 on Windows 10
If I start a drawing from the acadltiso.dwt and then try to type some text using the Multiline Text the text comes out in upper case. If I turn on the Caps Lock it still types in upper case and if I press the shift button it goes to lower case.
I have attached a file but can anyone help me with this as I would like to have the default as lower case and press the shift for upper case and also the Caps Lock.
EDIT
It is happening in all of my drawings - whenever I open a drawing it automatically types in upper case! I cant change it at all.
5 REPLIES 5
cadffm
in reply to: JamesPowell7164
Hi James @pendean (lol)
you are talking about the acadltsio.dwt, but how is it in ALL OTHER files?
I guess it is the same, in this case you turned on the TextAllCaps option (available since version 2015),
heck your help[F1] about it.
Sebastian
JamesPowell7164
in reply to: cadffm
I will try thanks
I am not @pendean (lol) but he is always so helpful when he comes on here (TRUE!!)
hwalker
Found it in the link below type TEXTALLCAPS and change the value to 0
Text always types in uppercase letters in AutoCAD | AutoCAD | Autodesk Knowledge Network
Howard Walker
Left Handed and Proud
JamesPowell7164
in reply to: cadffm
Genius although I dont know how I changed that - I didnt even know it existed!!
Thanks for your help.
pendean
@JamesPowell7164 FWIW there is no point tagging me in these forums: I have notifications turned off.
Forma Design Contest
Technology Administrators
