Hi Guys @pendean
I am running AutoCAD LT 2022 version S.74.0.0 AutoCAD LT 2022.0.1 on Windows 10
If I start a drawing from the acadltiso.dwt and then try to type some text using the Multiline Text the text comes out in upper case. If I turn on the Caps Lock it still types in upper case and if I press the shift button it goes to lower case.
I have attached a file but can anyone help me with this as I would like to have the default as lower case and press the shift for upper case and also the Caps Lock.
EDIT
It is happening in all of my drawings - whenever I open a drawing it automatically types in upper case! I cant change it at all.
Solved by hwalker. Go to Solution.
Solved by cadffm. Go to Solution.
Hi James @pendean (lol)
you are talking about the acadltsio.dwt, but how is it in ALL OTHER files?
I guess it is the same, in this case you turned on the TextAllCaps option (available since version 2015),
heck your help[F1] about it.
Sebastian
Found it in the link below type TEXTALLCAPS and change the value to 0
Text always types in uppercase letters in AutoCAD | AutoCAD | Autodesk Knowledge Network
Howard Walker
