Hey everyone,
I've got 20 pdf files, each contains approx. 100 pages and I need to convert all of them to dwg. Is there any solution I could manage it apart from manually converting pages one by one? Thx much for any suggestion.
Solved by Johneng. Go to Solution.
No problems. Use this:
Thanks much, nevertheless there is one more problem. When I start AutoViewport, select files and click start, it shows error "unable to open and connect autoCAD", although I've got it installed and even opened. I'm using autoCAD 2020 trial version. Is there a way to solve this?
I apologize, I did not pay attention to LT - this is only for the full AutoCAD.
In LT it is not possible. Nothing works in it - there is no lisp, no vba, no other programs.
You could write a simple script file. Something similar to this. Just change the file name and insertion point for your specific PDF file needs. You can use the attached txt file as a starting point. Modify for your needs and then change the extension to scr. Then run the script command.
