I would like to know how to add the name of each feature beside the name of the command. I have Autocad Lt 2015. The move button doesn't say the word "move" beside it, but I saw that all of the commands were labeled when I watched some videos. How do I turn on this feature?
Chad
Solved by pendean. Go to Solution.
Solved by john.vellek. Go to Solution.
Hi charrisonBYSHP and welcome to the Community Forums!
Can yo show me a screenshot of what you are trying to see on your display? Are you looking for the Tooltips feature? This can be turned on in Options>Display.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
You have several days to do this? CUI command, you go to every instance of every button on every panel on every tab in the Ribbon and you change this:
The words move, rotate, etc, appear beside the command. I am using Autocad for the first time, so I need it to be as simple as possible. How can I turn on this feature. The second picture shows my current screen, which doesn't list the names.
Chad
I thought it would be one option. I didn't know it was that involved. That's answers my question. Thanks for the help.
