Toolbars not moving with program window
I am running ACAD 2016 LT and I am using a dual monitor setup with my laptop.  I only ever use the program on a single monitor at any given time, but it's nice to use the larger monitor when I am in the office.  My issue is that when I grab the program window and drag it to the second monitor, all of my toolbars stay on my laptop screen.  They are all locked, so I am not sure why thay are not moving with the drawing window.  I can unlock them and drag them to the second screen, but if I forget to drag them back to my laptop before I go home they are not there when I open the program.  I have tried unlocking them, and they still stay on the other monitor when I drag the window.  Any ideas would be appreciated.  Thanks!
rkmcswain
You'll have to dock them. Floating toolbars are just that - floating.
R.K. McSwain     | CADpanacea | on twitter
Thank you.  I knew it was something silly causing the issue.  It seems the older versions I have used to automatically dock the toolbars.  I just had to find where you dictate where they are docked or floating.  Glad I could give you an easy question to answer.  I appreciate the reply.
