I work with AutoCAD LT designing 2D layouts for the long lengths of cold cathode lighting. We do design elaborate eclipse and spline shapes and one obstacle I always face is...
That the more complex and large radii curves are bent by hand and one problem we have for example is say breaking a large eclipse into 5 pieces. Our maximum lamp length is 2m, so for bigger projects that is our building block, to create the overall "seamless" lighting.
The problem is that we can obviously estimate what lamp length we require but there is always a margin of error so lamps are always over the length and adjusted to fit over each other.
What I want to do with our layouts is to take and eclipse, break it into 5 equal parts and AutoCAD can produce the lamp length that is more accurate than our calculations, and we can produce better fitting lamps.
Is there a function or method to taking splined shapes and adding points or cuts at definable distance along the feature? Any pointers or links would be appreciated as I have failed to make AutoCAD function for me on this!
