Cannot use Flatten command in LT
EmreYucel34
1,095 次查看
2 条回复
1 条消息(共 3 条)
EmreYucel34
Hello, the flatten command in Autocad is unfortunately not available in LT, can you help me how you can solve this situation in LT, thanks
0 个赞
1,096 次查看
2 条回复
回复 (2)
2 条消息(共 3 条)
h_s_walker
Which version of LT do you have?
Howard Walker
Left Handed and Proud
0 个赞
3 条消息(共 3 条)
pendean
Community Legend
Community Legend
Select all of your objects in the file (ensure all layers are unlocked/thawed/on), open PROPERTIES command, at the very top use the pulldown to sort by object type, then scroll down the long list to ever "Z' entry and manually replace whatever is written there to 0 (that's a zero, do it even if you see a zero).
Read all about it (and more) here from Autodesk
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/how-to-flatten-a-d...
If it takes you more than a minute for a DWG file I'd be very surprised.
FLATTEN command in full AutoCAD also destroyed 3D Solids and 3D blocks to make then 2D: there is literally nothing in LT, even with LISP in 2024/2025, those core commands are just missing.
