how to convert coordinates from google earth pro to open with autocad
zechariah_hou
zechariah_hou
Community Visitor
Community Visitor
how can i open google earth pro data with autocad
vladimir_michl
E.g. with the _GEOMARKPOSITION command. Or what do you want to achieve? See e.g. https://www.cadforum.cz/en/tips.asp?t=GPS
Vladimir Michl, www.arkance-systems.cz  -  www.cadforum.cz
pendean
Community Legend
Community Legend
Is this what you are looking to do
https://support.plexearth.com/hc/en-us/articles/4851057462161-How-to-display-the-Same-Geographic-Coo...
Otherwise I suspect you are using the incorrect software (LT) and should be using something else (Lap3D)
https://forums.autodesk.com/t5/autocad-map-3d-forum/is-there-the-correct-way-to-import-points-from-g...
