AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
~ BUG -- # Charter in Block Names -- Invalid Old Name
4 REPLIES 4
1450 Views, 4 Replies
This seems like a simple problem buy I have not found any documentation
on this bug.
I want to insert a file as a block
The filename is "WIRE#_L"
The block inserts fine, all attributes are editable with DDATTE
I can not redefine the block
Tried to use the ATTREDEF Command in AutoCAD200 and was prompted that
"WIRE#_L" was a invalid block name.
I returned to AutoCADLT2000 and tried to use the RENAME command.
When I opened the rename window I saw "WIRE#_L" as a block listed in the
drawing. I clicked on WIRE#_L, WIRE#_L was put into the old name field,
I then typed in anything for a new name, I clicked OK and got a popup
window "Invalid old name specified!"
What Gives????
If I change the file name of WIRE#_L to WIRE_L and insert the file as a
block in a new drawing, I can rename and redefine the block with no
errors or old name warnings.
From this I can only conclude that the # symbol is a taboo charter and
should not be used in filenames or block names for AutoCAD software.
I was also able to reproduce this error in AutoCAD2000 and in
AutoCAD200LT.
I called the AutoCADLT tech support number and the person I spoke with
did not even know that you could rename blocks with the rename command.
He took my numbers and said a "Level 2" representative would call me
back.
Any advice? I have now inserted WIRE#_L in a lot of my drawings and now
I need to redefine the block in all the drawings. Since I can not
rename or redefine the block I am stuck. Only alternative is to delete
all WIRE#_L blocks and reinsert a new block definition and re enter all
my date into the attributes.
John Collyer
AV Washington
4 REPLIES 4
Here is what you need to do.
try inserting the block but there is a little trick.
-insert or -i
WIRE#_L(block name in the drawing you want to change)=wire_l(block outside
of the drawing that you need to change)
So this is what the information should look like...
-i
-INSERT Enter block name or [?] : wire#_l=wire_l
Block "wire#_l" already exists. Redefine it? [Yes/No] : y
Jeff M.
PS you may want to put this info into a script and then all you have to do
is press a button and the script would run automatically in your drawing.
"John Collyer" wrote in message
news:399AD9B9.FEADF2FF@avwashington.com...
> on this bug.
> What Gives????
> AutoCAD200LT.
> back.
> John Collyer
> AV Washington
Place a back-quote in front of the pound sign (#) in the Old File name box.
This will allow you to rename the block by ignoring that character. The
back-quote key is on the tilde key in the upper left corner of the keyboard.
Another option (discovered by John) is to use rename from the command line
(-rename). This way you don't need to add the back-quote in front of the
pound sign.
Debbie Mohorovich
Autodesk Product Support
Jeff Milos (Kasian Kennedy) wrote in message
<9C8F3BCB89946DFB46D64495F8693AF8@in.WebX.SaUCah8kaAW>...
>-insert or -i
>-i
>Jeff M.
>> on this bug.
>> What Gives????
>> AutoCAD200LT.
>> back.
>> John Collyer
>> AV Washington
>What Gives????
Tthe dialog version of the rename command allows you to use wildcard
characters to rename objects, and the # character is a wildcard
character which stand for 'any numeral'. Use the command line version
instead:
-rename
block
WIRE#_L
Something
Or tell the dialog not to use # as a wildcard but as a character. This
is done using the backquote character.
Dietmar Rudolph
President, CR/LF GmbH, http://www.crlf.de
Vice-President Europe, CADLock, Inc. http://www.cadlock.com
Webmaster, AutoCAD Developers Group Europe, http://www.adge.org
Member of the Autodesk Discussion Forum Moderator Program
Author, "Mastering AutoCAD 2000 Objects", http://www.crlf.de/Verlag/PublishingServices.html
astral.engenharia.fabio
Perfect thank you! It worked!
-rename
block
WIRE#_L
Something
Forma Design Contest
Technology Administrators
