>When I opened the rename window I saw "WIRE#_L" as a block listed in the
>drawing. I clicked on WIRE#_L, WIRE#_L was put into the old name field,
>I then typed in anything for a new name, I clicked OK and got a popup
>window "Invalid old name specified!"
>What Gives????
Tthe dialog version of the rename command allows you to use wildcard
characters to rename objects, and the # character is a wildcard
character which stand for 'any numeral'. Use the command line version
instead:
-rename
block
WIRE#_L
Something
Or tell the dialog not to use # as a wildcard but as a character. This
is done using the backquote character.
Dietmar Rudolph
President, CR/LF GmbH, http://www.crlf.de
Vice-President Europe, CADLock, Inc. http://www.cadlock.com
Webmaster, AutoCAD Developers Group Europe, http://www.adge.org
Member of the Autodesk Discussion Forum Moderator Program
Author, "Mastering AutoCAD 2000 Objects", http://www.crlf.de/Verlag/PublishingServices.html
