Blocks Palette Libraries Tab Error "File not found"
bill6WQCP
Observer Observer
Message 1 of 29
bill6WQCP
Observer
Observer
AutoCAD LT 2023.  When I go to Blocks Palette Libraries Tab to build library i get the error message "File not found", and fortunately I am able to click on out of the error.
Replies (28)
Message 21 of 29
pendean
Community Legend
Community Legend
@andrew7CTM8 @alfonzogary We are all end users just like you around here.
May I ask, are you both not be on subscription? I'd understand why you'd shy away from asking Autodesk to help you fix the issue then. Just as a reminder, if you are on subscription, you are paying Autodesk to help you fix this problem.
>>>... I dont know how this was marked as solved...<<<
I was not in their head to know.
Message 22 of 29
alfonzogary
I had this issue come up in an Auto CAD fundamentals class I teach. One of the students got that error message. It’s not something I’m currently struggling with, so I’m not going to waist my time. The IT guy’s will probably be installing 2024 soon, so mute.
Thanks.
Message 23 of 29
Attilio_Armone
Hi @pendean ,
I'm having the same issue, how do I add a link to my libraries? is there a folder we can change the path from "Settings" by any chance?
Message 24 of 29
pendean
Community Legend
Community Legend
Greetings @Attilio_Armone
As far as I know, once you get that type of error in the Libraries Tab in the Block Palette, you will be forced to reset your AutoCAD back to defaults to fix it.
If you'd rather not do that or that did not work, then open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help like this
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-find-my-sup...
If you are on a free educational license... EDU Support Access is here, look for the new automated pop-up with common questions
https://www.autodesk.com/education/support?startHelpBranch=AVA-edu-flow&mode=open&_ga=2.35539169.196...
and here https://forums.autodesk.com/t5/installation-licensing/education-license-renewal-lacks-renew-option-o...
Message 25 of 29
Dominik.Pongrac
Community Visitor
Community Visitor
Alt+F4 will get you out of that window.
Looks like some kind of bug that doesn't show close button.
Message 26 of 29
alfonzogary
If it ever happens again maybe I'll remember to try that. Is Alt+F4 some sort of computer hack? What made try or think of that?
Message 27 of 29
pendean
Community Legend
Community Legend
Message 28 of 29
Rob_HudsonX943E
Community Visitor
Community Visitor
To fix this without reinstalling, do the following:
1. Navigate to insert tab
2. Navigate to the insert button drop down
3. Select Blocks from libraries
This bring up the option to select a libraries icon in the block pallet
4. Select a dwg file that contains your blocks
And like magic the Block Libraries tab now works even after restarting
This one had me stumped for a bit.
Cheers
Rob Hudson
Message 29 of 29
rjdaggett
Observer
Observer
Thanks Rob!
I managed to find this solution from Reddit of all places, however I
definitely appreciate your answer here as it will help others.
As well, par for the course with autoCAD there is more than one solution to
any problem.
