Block Transparency Not Correct when Used with Multileader
whitt0213
whitt0213
I have a block which has transparency set to ByLayer. This block works perfectly normal when used by itself - meaning the transparency changes if the if layer is changed. However, I have tried using this block with a multileader and the leader has the correct transparency of the layer, but the block is displaying as if it has transparency of 0. The properties show that the transparency is still ByLayer. Other attributes, such as the color, change correctly if moved to a different layer - it seems that transparency is the only thing not working correctly.
pendean
Community Legend
Community Legend
That's a known issue (no fix?) but... Share your DWG file with that block and separate mleader side by side on that layer please.
whitt0213
Thanks for the reply - that really stinks. Here's an example .dwg.
pendean
Community Legend
Community Legend
try this: use BEDIT command to open your block, select EVERYTHING, then select this
To get this
whitt0213
This works for existing multileaders, but in the instance I need to copy the multileader - or, insert it from a tool palette, it gets reset. We have thousands of these across hundreds of .dwgs. Thank you, though.
pendean
Community Legend
Community Legend
@whitt0213 wrote:
...I need to copy the multileader - or, insert it from a tool palette, it gets reset. We have thousands of these across hundreds of .dwgs....
Sadly the core of the program needs to be changed by Autodesk.
