AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Rotating or Angling Text not cooperating
5 REPLIES 5
mbetGEGZX
147 Views, 5 Replies
Had this problem in the past but solution not working this time. I'm trying to put text at a 45 degree angle. The entire text will move but remains horizontal. Desperate for help.
Tags (1)
5 REPLIES 5
pendean
in reply to: mbetGEGZX
@mbetGEGZX I did notice ROTATE command everywhere does something different in this file too.
Did you mean to do this?
mbetGEGZX
Two Things: 1. How does one get into the TextStyle dialogue box? (Yep, I'm that bad)
                        2. Changing the Match Orientation did the trick
THANK  YOU!
paullimapa
Use the STYLE command
Paul Li
IT Specialist
@The Office
mbetGEGZX
Of course!
Thanks again for the help!
paullimapa
You are welcome…cheers!!!
Paul Li
IT Specialist
@The Office
Technology Administrators
