We have updated to LT 2015 version. However a very annoying 'feature' has been introduced.
When selecting the 'Insert' button on the Block panel from the ribbon, a dropdown box appears with previews of all the blocks in the library. We then have to select the 'More Options' button to get the regular window up.
Is there a preference setting to not allow this preview come up? with over 100 blocks to preview it is impractical to use and takes several seconds to load each time we insert a block.
Cheers
Solved by pendean. Go to Solution.
I am not a fan of Galleries either.
Maybe just use INSERT command from the commands line. The shortcut is simply "I"
Thanks Nestly2, I will pass this on to our other users as well.
I seem to be using a lot more commands in 2015 than i had to in the 2010 version i upgraded from, a bit dissapointing really as I can see they are trying to move away from this.
