battman doesnt seem to work for attribute text height
christian_serena
Message 1 of 15
christian_serena
Hi all,
I have several blocks within my drawing. Since the attribute text is too small, I changed font size in the attribute with BATTMAN however it seems to affect just the block that I have selected for attribute editing. Neither Attsync or RG  seem to work.
Any help?
Thnak you
christian
Replies (14)
Message 2 of 15
h_s_walker
If you can post the block so we can have a look at it
Howard Walker
Left Handed and Proud
Message 3 of 15
christian_serena
Ok, here you go.
In the legenda you can find two blocks: Either "001_MEC_Aeraulico_Serrande Tagliafuoco" or "serranda con motore" that have the right font size. In the plan below you'll find a number of occurrences of the same blocks.
Thanks in advance
christian
Message 4 of 15
h_s_walker
It seems to work for me. See the image below. I'm only on LT2016. The one thing I can't work out though is why I can't change the text height on 001_MEC_Aeraulico_Serrande Tagliafuoco. It's always greyed out for me
Howard Walker
Message 5 of 15
christian_serena
As far as I can see the greyed one is the text justification, not the height. Do I see right?
However battman issue still remain. Could be any Autocad setting since it is working with you and not with me?
thanks again
christian
Message 6 of 15
h_s_walker
@christian_serena No I couldn't change the height. See the image below
Howard Walker
Message 7 of 15
RSomppi
Does the text style have a designated text height?
Message 8 of 15
h_s_walker
@RSomppi Nope it has a 0 height the same as his Romans textstyle
Howard Walker
Message 9 of 15
cadffm
Just a bug in the program,
while attdef justification is on center, you can't change the height, this is  without a logical reason.
Sebastian
Message 10 of 15
christian_serena
There in your screenshot, the block attributes aren't even visible. This adds another issue, the same file have attributes behaviour that changes from one machine to another, let alone Acad LT versioning - so stifling!
To make it simple, I believe is something connected with environment variables... any clue anyone here?
I have autocad LT 2023
Thanks again
christian
Message 11 of 15
h_s_walker
@christian_serena That's because I'm on the text format tab. If you look at my screenshots you will see that Attributes are on the first tab
Howard Walker
Message 12 of 15
christian_serena
Agree, however I am referring about attributes on the drawing, not on the "edit attribiute" window.
In this shot from my drawing you can read "STF..." that are attribute which text I need to enlarge all at once, visibile in my drawing and not in yours
Message 13 of 15
cadffm
Sebastian
Message 14 of 15
pendean
Community Legend
Community Legend
Greetings @christian_serena
Looks like you need to upgrade from LT to full AutoCAD, to gain access to this alternative command to do the manual edits you wish to do
In the meantime... Open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://knowledge.autodesk.com/customer-service/account-management/users-software/support-options#:~...
Message 15 of 15
christian_serena
What a fool! 🙈
