Hello i am sorry if there is a solution for this and i could not find it.
I am trying to batchplot all of my drawings but only need the layout 1 from each drawing. i am currently inserting the drawings to be batch plotted then selecting them all and unselecting layout 1 through all of them them deleting the selected layout 2 and 3. this is very tedious and time consuming when im batch plotting 300 drawings and need to select layout 2 and 3 to be deleted. Is there a way to sort them by layout name or only insert layout1 from a list of drawings to be plotted? any help or info on this would be greatly appreciated.
Batchplot(Publish) all the layouts including model to a dummy folder, open that folder and search for *Layout1. Then you only see all layout1 PDFs, If you set your file view to details, then you can see much clearly. Select all and move to the correct folder. Publishing may take some time but manual efforts will be reduced.
