AutoCAD LT Forum
Batchplot layout1 only
2 REPLIES 2
341 Views, 2 Replies
Hello i am sorry if there is a solution for this and i could not find it.
I am trying to batchplot all of my drawings but only need the layout 1 from each drawing. i am currently inserting the drawings to be batch plotted then selecting them all and unselecting layout 1 through all of them them deleting the selected layout 2 and 3. this is very tedious and time consuming when im batch plotting 300 drawings and need to select layout 2 and 3 to be deleted. Is there a way to sort them by layout name or only insert layout1 from a list of drawings to be plotted? any help or info on this would be greatly appreciated.
Tags (3)
2 REPLIES 2
pendean
Start using SSM (SheetSet Manager) upfront, then you can create special sets that suit your need all day long and reuse as often as you need https://www.autodesk.com/autodesk-university/article/Managing-Your-Sheets-Sheet-Set-Manager-2019
Or... after you sort manually through PUBLISH command to only keep what you want, use the option to save your set in PUBLISH to reuse later.
As you know, automation only comes from pre-planning ahead of time.
Nope, in LT, there is not much else you can do. Sorry.
janu319
Batchplot(Publish) all the layouts including model to a dummy folder, open that folder and search for *Layout1. Then you only see all layout1 PDFs, If you set your file view to details, then you can see much clearly. Select all and move to the correct folder. Publishing may take some time but manual efforts will be reduced.
Technology Administrators
