Welcome to the Forums
If you're trying to run a script in LT the command is just SCRIPT filename.scr
Howard Walker
no, trying to call script from script, and found this new command scriptcall, but my AutoCadLt says that it is "Unknown commad"
Is there something I don't understand abou this command?
Should it work, Help says it should?
Ok, thanks.
Our company just moving to LT2017, so not very happy that Help isn't up to date
I see what you mean. I've just tried using it in a script file and it comes up unknown command. Even when typing it in on the command line it doesn't show up.
What exactly are you trying to do with the script files?
Howard Walker
Ignore that
Howard Walker
Ok, thanks for the info.
I'm just a tester, don't know the type of license our company is using...
I made a note for our QA team regarding the help documentation in AutoCAD LT 2017.
Although the command is not available in the 2017 release it is available as stated in other messages in AutoCAD LT 2018.
If you are on subscription your company should have access to the newest release and 3 years back from that release.
Post back if you are unable to run 2017 and 2017, I'll do my best to assist with your licenses or transfer your thread over to our I&L team.
