AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Autocad zooms when I want to paste
6 REPLIES 6
fransHQQDQ
228 Views, 6 Replies
I hope anybody can help me with the following question:
When I want to paste anything in modelspace or block editor, my autocad keeps zooming when I click the insertion point
Greetings,
6 REPLIES 6
pendean
in reply to: fransHQQDQ
You probably need to turn off UCSFOLLOW command in the DWG file you are in: look up that command in HELP in the program.
fransHQQDQ
in reply to: pendean
Tried but sadly didn`t work
pendean
That's unfortunate.
Did you reboot your PC yet?
Try different DWG files (to and from) to see if the issue is only with your destination or source file?
Confirm your "paste" method is not also adding other commands and settings?
Do you have an add-on to your AutoCAD?
Is your AutoCAD fully updated and current? And how do you find out it is or sure if you think the answer is yes?
fransHQQDQ
Did you reboot your PC yet? Yes
Try different DWG files (to and from) to see if the issue is only with your destination or source file? All files the same
Confirm your "paste" method is not also adding other commands and settings? Check
Do you have an add-on to your AutoCAD? No
Is your AutoCAD fully updated and current? And how do you find out it is or sure if you think the answer is yes? Autocad LT 2023 - Fully updated according Autdesk Acces app on PC
Still doesn`t work
pendean
@fransHQQDQ Thank you so much for taking the time to answer each of my question.
I suspect your next steps are:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-reset-AutoC...
and possibly
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Clean-uninstall.ht... followed by a reinstall.
OR... Here are ways to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/account/manage/use/support#:~:text=com/plans.-,Contact%20support,-S...
fransHQQDQ
Thank you very much,
for today I installed 2024 but it had the same problem.
later I installed 2025 and this didn`t have the problem.
Tomorrow I will try your reset to see if this helped just to know the solution for this in stead of working with 2025
Forma Design Contest
Technology Administrators
