AutoCAD LT Forum
AutoCad Question
2 REPLIES 2
383 Views, 2 Replies
AutoCad Question
I've been having trouble answering these two questions. I've already submitted them but I would still like to know what they are.
To draw a line a length of eight feet, four and five-eights inches in the 12 o'clock direction from the last point selected, type
A) @8'4-5/8<90
B) 8'4-5/8<90
C) @8'-4-5/8<90
D) None of the above
The "C" option used in the LINE command at the "To Point:" prompt will
A) continue the line from the last line that was drawn.
B) close the previous set of line segments.
C) both a and b
D) none of the above
2 REPLIES 2
pendean
F8 to run on ORTH
LINE command
click the start point on screen
drag the cursor in the direction you want to go
type
8'4-5/8
then hit <enter>
All done.
Are you trying nto cheat to pass a test, or has no one ever shown you this classic tip?
You can answer Q2 yourself in AutoCAD. Do so now.
Emmsleys
Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
To add;
1. None of the above
2. both continue and close
Sarah Emmsley
Technical Support Specialist
”Boost
