I've been having trouble answering these two questions. I've already submitted them but I would still like to know what they are.
To draw a line a length of eight feet, four and five-eights inches in the 12 o'clock direction from the last point selected, type
A) @8'4-5/8<90
B) 8'4-5/8<90
C) @8'-4-5/8<90 D) None of the above
The "C" option used in the LINE command at the "To Point:" prompt will
A) continue the line from the last line that was drawn.
B) close the previous set of line segments.
C) both a and b
D) none of the above
Solved by pendean. Go to Solution.
Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
To add;
1. None of the above
2. both continue and close
