Using AutoCAD LT 16.
Converting an elevation view from PDF to DWG. It has a horizontal scale (1" = 120') and a vertical scale (1" = 12').
Is there a way to scale this elevation view so that I have the correct horizontal distances and vertical elevations?
Thanks!
Put it in your drawing twice have one of the objects 10x smaller or greater than the other.
Howard Walker
Try bringing it in as a PDF and then adjusting the X and Y as @ steven-g suggested.
Are you only using AutoCAD LT? Are you using other Autodesk product's too?
Following up on your thread, were you able to find a solution or a workaround? Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
