I plot to Bluebeam to create a PDF. The plot was vertical so I changed it to landscape. I selected save the change versus save to a temp pc3 file. Now, when I select plot, it will go through the motions of plotting but produces nothing. I have searched my entire computer for a PDF plotted today to no avail. I have clicked on the plot details window that appears and the plot file path is blank. I went to the options command and confirmed the plotter configuration was correct. How can I get my path back on track?
[ The subject line of this post has been edited for better findability by @handjonathan Original: plot file path disappeared ]
Solved by pendean. Go to Solution.
I had the same issue. This specific link solved the problem:
https://support.bluebeam.com/articles/save-as-window-never-appears/
I tried this one first, but it didn't seem to change anything. In case the "save as window never appears" doesn't work, this could be worth a shot:
https://support.bluebeam.com/articles/changing-the-default-folder-options/
“Save As” dialog never appears when creating PDF documents:
https://support.bluebeam.com/articles/revu-save-as-dialog-never-appears-when-creating-pdf-documents/
