AutoCAD LT - Moving the same vertex - on different layers
richard.caudill
Observer Observer
richard.caudill
Observer
Observer
I have a drawing that is used for mapping. We use multiple layers to distinguish advancement on the map.
For instance I have a square with two different layers of the square. Each layer has the same exact vertex points. Is there a way to move both layers vertex at the same time to a point/location that is selected.
The picture posted… top right corner of the box. Has a vertex on the orange layer, and a vertex on the blue layer as well.. how could I move the vertex on both layers at the same time?
thank you
[ The subject line of this post has been edited to include the product name by @handjonathan ]
cadffm
Use the STRETCH command (and cross selection)
Sebastian
richard.caudill
Observer
Observer
Ok, I’m a slight beginner, so I hope you bare with me. I selected stretch. Upon selecting object it selects the whole square not vertex… I got it to do it once by luck.. so far I haven’t been able to do it again. Instead I move the whole object.
—- also I’d like to be able to move the vertex’s to another midpoint instead of just a free stretches if that makes any sense?
cadffm
Okay,
Start the command Stretch,
Click on an empty place right of the vertex.
Acad ask for a second point now,
click into an empty space left of the vertex, which have to be inside the cross selection area.
Try it
Sebastian
handjonathan
Hi @richard.caudill
Thanks a lot for posting your question to the forums!   Has the solution suggested by @cadffm helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
