AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
AutoCAD LT Message
4 REPLIES 4
526 Views, 4 Replies
AutoCAD LT Message
Hi!
ISSUE.PNGI got problem to disable (swich off) message witch appears when I try to edit text. The message what shows are: AutoCAD LT Message (Unable to find dictionary) Could not start speller [CHECK PICTURE]. Its a bit annoying when every time you need to edit text the message appears. So looking for a hand here. Any ideas?
4 REPLIES 4
For your concern please see the link below.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-...
Try it 😉
I do like in link you show, but I got this and I cant do anything.ISSUE2.PNG
I got something like this. I try reset my AutoCAD and that not helping me much.ISSUE2.PNG
pendean
What about doing the other three things noted in the linked document before the reset?
DCTMAIN is set to what?
Does the 'sample.cus' file exist where it's noted in the linked document?
Any reason you cannot link on the NONE AVAILABLE and go find the document at the path noted above?
Technology Administrators
