Hi!
I got problem to disable (swich off) message witch appears when I try to edit text. The message what shows are: AutoCAD LT Message (Unable to find dictionary) Could not start speller [CHECK PICTURE]. Its a bit annoying when every time you need to edit text the message appears. So looking for a hand here. Any ideas?
Solved by pendean. Go to Solution.
For your concern please see the link below.
Try it 😉
