AutoCAD LT Forum
AutoCAD LT crashing uncontrollably
8 REPLIES 8
Message 1 of 9
514 Views, 8 Replies
Starting today, AutoCAD LT started crashing unexpectedly causing me to loose a bunch of work. What's going on? I've sent a bunch of reports but this is riddiculous.
8 REPLIES 8
Message 2 of 9
pendean
What year version is this?
Your OS?
What does your IT person see changing on your PC and/or where you store your files today that is different from last week?
Message 3 of 9
rkmcswain
Anytime you do something worth saving, run the QSAVE command. You won't lose any work this way.
Unless the QSAVE command itself is causing the crash of course.
Message 4 of 9
in reply to: pendean
Its AutoCAD LT 2020 running on Windows 10 that has taken in all the recent updates.
Nothing changed. It was fine in the morning - on for a couple of hours then the computer was off for one hour then this happened. AutoCAD crashes after about 10 min of work.
Message 5 of 9
rkmcswain
Whether you realize it or not, something changed. Could be the data files you are working on, Windows updates, some other application replaced a DLL, etc., etc.  Do you have, or can you create a separate Windows user account on this PC? If so, switch to it and repeat your actions under this other user account. Do the issues go away?
Message 6 of 9
in reply to: rkmcswain
I did as you suggested and started AutoCAD in a new user account - it went through the motions of first run, doing its setup and such. I worked on the same file for a bit and it didn't crash. I admit I'm a little impatient and didn't want to wait too long - but if this is the case that its something in my account than what should I do?
Message 7 of 9
rkmcswain
We have over 500 users and I see this happening about once a week. To solve, we reset the user's settings, which is essentially what you have accomplished (as a test) by using a different Windows login.
Message 8 of 9
Ok. Does this mean I shouldn't migrate my settings?
Message 9 of 9
Resetting has indeed resolved the issue! Thank you kindly!!!
Forma Design Contest
Technology Administrators
