AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
AutoCAD LT 2014 - Problems running on Windows 11
5 REPLIES 5
perisysanchis
2045 Views, 5 Replies
perisysanchis
Observer
Observer
Hello everyone, I have a problem with my Autocad 2014 running on Windows 11.
In many cases Windows crashes and I have to restart the system.
Other times the program freezes for seconds or minutes and then works.
Someone else happens?
Thanks.
[ The subject line of this post has been edited for clarity by @handjonathan Original: Problems Autocad LT 2014]
Thanks.
Tags (1)
5 REPLIES 5
rkmcswain
in reply to: perisysanchis
rkmcswain
AutoCAD 2014 came out years 9+ years ago, way before Windows 11. It's not supported.
It may work, or it may not, as you have seen.
Perhaps if you had some specifics, we could make suggestions.
R.K. McSwain     | CADpanacea | on twitter
pendean
pendean
Community Legend
Community Legend
Are you going to pretend you don't know the system requirements for LT2014 😉
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/System-r...
IN the meantime... did you install all of the LT2014 updates required to make it work in the first place? It helps many in Win10, so Win11 may behave after that too, who knows.
The Update does not magically install themselves, start here https://knowledge.autodesk.com/support/autocad-lt/troubleshooting/caas/downloads/content/autocad-lt-... then if needed here https://ava.autodesk.com/modular/
Good luck.
Good luck.
rkmcswain
in reply to: pendean
rkmcswain
No wonder @perisysanchis hasn't come back.
perisysanchis
Observer
Observer
I speak to you from complete ignorance as I have never worked on Windows 11 and have encountered this problem.
Thanks for the reply.
rkmcswain
in reply to: rkmcswain
rkmcswain
Open what "prog"?
Please include screenshot of the error.
We need more information please.
@cgruen
Open what "prog"?
@cgruen
Technology Administrators
