Hello everyone, I have a problem with my Autocad 2014 running on Windows 11.
In many cases Windows crashes and I have to restart the system.
Other times the program freezes for seconds or minutes and then works.
Someone else happens?
Thanks.
[ The subject line of this post has been edited for clarity by @handjonathan Original: Problems Autocad LT 2014]
Thanks.
Solved by rkmcswain. Go to Solution.
AutoCAD 2014 came out years 9+ years ago, way before Windows 11. It's not supported.
It may work, or it may not, as you have seen.
Perhaps if you had some specifics, we could make suggestions.
No wonder @perisysanchis hasn't come back.
I speak to you from complete ignorance as I have never worked on Windows 11 and have encountered this problem.
Thanks for the reply.
