I just bought a new laptop and installed my AutoCAD LT 2014 on it. When I open AutoCAD LT everything seems to be fine. However, the first time that I try to switch to a different command tab or open layer properties, or anything similar AutoCAD LT immediately crashes.
My new laptop is:
Could the problem be the graphics card?
Solved by Tarek_K. Go to Solution.
File content does seem like a possibility.
Did you fully uninstall the previous version? What ever was causing the crash may still be there if you didn't.
If you don't think it is a file issue, do a full uninstall of both versions and reinstall 2020.
Have you done a search on that error? There's a lot out there and it doesn't look good on the surface.
Hello @bglong,
thank you sharing what helped with one of your drawings. At least one step forward in the right direction! Hope you´ll figure out a way that also works for the other drawings. I guess your progress might also be interesting for all the people who helped so far. Feel free to post here when you learn something new and/or make progress so others might suggest new things on the fly alongside your progress.
Feel free if you see it fit to mark your previous post as solution (at least with the actions you took for the one file) so others can find that one to start with in case they encounter the same problem.
Keep us here in your topic how it goes!
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Tarek Khodr
