AutoCAD LT Forum
Welcome to Autodeskā€™s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Autocad lt 2013 files are disappearing or not saving updated versions.
7 REPLIES 7
Message 1 of 8
255 Views, 7 Replies
When saving files they either do not save to the most recent version or the files disappear completely even the .bak  versions. They appear in the recent list on auto cad but when clicked on it states that the file does not exist.
Windows 10 64bit
Auto cad Lt 2013
I have tried auto cad back up and disabled network drives to save locally.
7 REPLIES 7
Message 2 of 8
gotphish001
2013 is not supported by windows 10 and will have lots of bugs or not work at all. It seems to work longer or shorter for some people but eventually everyone's seems to break.
Nick DiPietro
Cad Manager/Monkey
Message 3 of 8
pendean
LT2013 is not designed for WIn10.
Ensure you do not have ISAVEPERCENT variable set to anything other than 0 (zero) and see if that helps.
Also check where you are saving your files to, it appears you have other issues that may be going on if your files are disappearing.
Message 4 of 8
jayhar
Hi
Visit https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Files-...
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Message 5 of 8
in reply to: jayhar
I have already looked into this but I'm not using a network drive.
Message 6 of 8
in reply to: gotphish001
It was working absolutely fine on the previous updated windows 7 machine no bugs, bought a new windows 7 upgraded to 10 machine and was working fine until now.
Message 7 of 8
cadffm
"When saving files they either do not save to the most recent version"
Possible in some case, but is really happen if you set isavepercent=0
"or the files disappear completely even the .bak  versions"
The existing old DWG and also the(old existing) *.bak?
On a local drive?
Impossible would i say.
Corrupt, old but deleted?
Where is your folder? With path?
Which OS? Real enviroment or a virtual machine?
Sebastian
Message 8 of 8
cadffm
"was working fine until now."
So search for the last win10 update and remove them,
try it again.
Sebastian
Forma Design Contest
Technology Administrators
