Solved by pendean. Go to Solution.
LT2010 is not supported in Win10: not supported means if Win10 installs an update that breaks an otherwise working software there is no one on the planet working on changing that reality http://autode.sk/1IY4C2X
.NET3.5 requirement and installation method is explained here (for win8 but the concept is the same) https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/NET-3-5-error-when-insta...
I did the NET 3.5 install as suggested and I can open the program again. Thanks.
Guess, I need to upgrade to subscription versions soon...
