AutoCAD LT 2010 "Not Responding" on file open or file save
Message 1 of 28
System: Windows 7 Professional 64-bit
Problem: After having worked flawlessly for about a year, yesterday I was unable to either save or open files. I can draw and plot just fine. I tried using both "Repair" and "Reinstall" from the Windows Control Panel. Unfortunately, having purchased the program by download from the Autodesk store, I don't have a CD from which I could do a total reinstall.
Thoughts?
Replies (27)
Message 21 of 28
Thank you all so much, just had the same frustrating day trying to solve the freezing issue when trying to open/save a file on LT2010. Read this entire thread, uninstalled Drop Box, voila! Other than in AutoCad I am pretty computer illiterate and this gave me a simple fix and saved me the cost of an IT trouble shooter who would probably have ended up on the forum anyway to find the problem. Thanks agin to all!
Message 22 of 28
Deleting Dropbox worked for me too. I had very similar problems with my LT 2008 today, and spent most of the day trying to sort it out. Hey presto, problem solved after uninstalling Dropbox. I might send a complaint (and a bill) to Dropbox.
Message 23 of 28
Emmsleys
To add to this thread, there has been an update for Dropbox which may cause a few problems with older releases of AutoCAD. The development team is aware of the issue and are working on it.
For additional help here is a link for steps to uninstall Dropbox. I will be sure to circle back with any updates.
Sarah Emmsley
Technical Support Specialist
Message 24 of 28
KIMMA8
Community Visitor
Community Visitor
As per previous replies, I went and deleted (uninstall) 'dropbox' and problem no longer exists. Hmmmmmm?
Message 25 of 28
mlinares
Observer
Observer
Thank for posting this solution, I spend several hours trying to figure out the same issue for AutoCAD MEP 2010. Problem solved.
Message 26 of 28
is there a fix for Dropbox yet? Working without Dropbox becomes more difficult as you need to save to an external HD to take it home to continue to work and do not forget to brig it back to the office the next day!
Waiting for a fix for this
Thank you!
Message 27 of 28
pendean
Community Legend
Community Legend
Are you too working with an old version of AutoCAD/LT like everyone else?
There are no problems with DropBox with AutoCAD/LT versions 2016 and higher here.
Message 28 of 28
Emmsleys
I know DropBox came out with a updated build that resolved the issues with AutoCAD LT.
What AutoCAD LT release are you working with?
Sarah Emmsley
