Autocad 2019 Object scale
I have just installed Autocad 2019. Now having issue with scaling an object using reference points? Using exact same procedure as 2018. I select object, select base point, select reference length but then when I select new length by snapping to another object point it seems to scale to a random point? Can anyone help?
Just realised that the it's only a problem in paper space. Model space works fine?
pendean
Community Legend
Community Legend
Is 2019 fully patched and updated https://forums.autodesk.com/t5/autocad-lt-forum/autocad-lt-2019-1-2-update/td-p/8276302/jump-to/firs...
Have you ever tried ALIGN command for the same match-scale function?
ChrisPreece
Hi @Anonymous,
I see you're posting for the first time. Welcome to the Autodesk Community, and thank you for posting your question here in the AutoCAD LT forum.
I'm just checking in to see if you need more help with this. Did the suggestion that @pendean provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Chris Preece
Technical Support Specialist
