Dimension Displaying
I am using the Auto CAD 2018 and I have a problem with the dimension command. It doesn’t display the dimensional numbers at all when I work in Metric template.
But it works normally when I set up the template in Imperial.  Please help me how to solve this problem. Thank you in advance.
Linh
pendean
Community Legend
Community Legend
Show us your work, post the affected DWG file here with the problem.
ChrisPreece
Hi @Anonymous,
I'm just checking in to see if you need more help with this.
As @pendean mentioned, you can always attach the DWG file to this thread for troubleshooting. If you're not able to share the DWG file, you could attach screenshots of your Modify Dimension Style dialog box. Just make sure you take a few screenshots of the various tabs so we can see how your DIMSTYLE is set up.
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Chris Preece
Technical Support Specialist
Thank you for your response. While I was waiting for the answer I opened a new template and tried setting up the dimension style as usual. Guess what? The dimension values appear normally.
For sure I did exactly setting up the template as before!
Thanks again!
Linh
