AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
AutoCAD 2017 fatal error on start up
4 REPLIES 4
929 Views, 4 Replies
While initializing the AutoCAD 2017, I am facing the similar problem. Showing FATAL ERROR message. Not able to open the Software.
4 REPLIES 4
Emmsleys
Hi @Anonymous,
Have you tried the following...
Try logging in under a new Administrator Windows Account.
If you create a new account and can successfully open the drawing, you can either use that account or rebuild the user profile in Windows.
See: How to create a new local administrator Windows user account
Sarah Emmsley
Technical Support Specialist
pendean
Emmsleys
HI @Anonymous
Following up on your thread, were you able to find a solution or a workaround? Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Post back if you need continued help on your thread.
Thanks for your time.
Sarah Emmsley
Emmsleys
I'm following up on my previous post if you have any questions or found a workaround post back with any new updates
If you still need help or have questions I'll be more than happy to help.
Thanks.
Please select Accept as Solution if my post or any other post in this thread resolves your issue, or reply with additional information if the problem persists.
Sarah Emmsley
Forma Design Contest
Technology Administrators
