i am running autocad lt 2015 on windows 8. i am missing the icons on the block authouring palette. i have the 4 groups but nothing in any of them.
i have tried a reinstall of autocad but still have the same problem. are there any files (.xtp or .xgt) files i can download to put the actions back onto the group palette.
Solved by paul_peat. Go to Solution.
Solved by edwin.prakoso. Go to Solution.
Try to import attached xtp files. I exported them from my AutoCAD LT 2015.
Cheers,
Edwin Prakoso
pendean, thanks for the sniping tool thats really handy.
edwin, where to i import the .xtp files to? also why are there only 3 files - actions, parameter sets & parameters when there are 4 group sets on the authoring tab.
i have a colleague who has just downloaded autocad lt 2015 who has no group palettes on his authoring palette, is this a problem with autocad?
regards
Paul
Open block editor. Right click your authoring palette title and choose Customize Palettes from context menu.
In opened dialog box, go to Authoring Palette tab. Right click on empty area in the left panel. Choose import.
What are the 4 groups of the authoring palettes? I only have 4 palettes, but no group as you can see above.
Cheers,
Edwin Prakoso
edwin,
i have imported the .xtp files into the authouring palette & they work fine.
on the original palette i have 4 tabs:- Parameters, Actions, Parameter sets & Parameters as screen shot, below these are the .xtp files i have imported which are Parameters, Actions & Parameter sets, therefore i think i have on tab missing. i'm new to dynamic blocks so dont know for sure if what i have is correct.
regards
Paul
edwin,
i have managed to find a .xtp file for the constraints palette(from full autocad 2012) which is now inserted & working fine as far as i can tell(not had a chance to use it properly yet plus not quite sure how to)
many thanks for your help
Paul
I cant even get the Authoring Palette to come up to click on. I have clicked and typed into command line. any ideas?
