Why after inserting a block do you have to zoom extents for the software autocad to operate at normal speeds, if you do not it is painfully slow.......though Autodesk would have solved this for 2020!!
ok thanks for your response...........I started having this issue with 2019 never had it before, admittable some of my block sare mongrels and may have bugs, but every block, some from scratch, I have to do the same to do it with every block. I noticed it and found on the net about Z E to resolve it.
My pc is less than a year old with Pentium 7 top-spec more than fast enough for using 2d draughting.
I think it might be the way in which the software has been installed, and possibly damaged some registers I've another issue with the processing becoming jumpy on file explorer and after installing 2020 without first removing 2019 since removed 2019 and reinstalled 2020 and it works fine.
Strange I don't doubt what you are seeing isn't real, but I use a fairly low-end laptop 5 or 6 years old, and have LT 2018 2019 & 2020 installed. I have also used Revit and Inventor on the same computer all without any problem. Maybe you should consider a reinstall. Are all your other drivers up to date?
it has consistently happened over the last year, therefore without checking all my drivers, I would say that it may not be my drivers as they would have been updated, surely, over the last year?
I forgot to mention, apologies, it is only this problem after saving a change I've made in the block editor tool, works fine for block insertion only, without the editor.
tried GRAPHICSCONFIG command turned off card and same thing happens, plus I'm using NVIDIA Quadro K620 which should be plenty powerful enough for autocad 2d draughting
tried regenall but same thing happens, Z E must do something different that Regen does not do.
thanks for the comments.
@stuart.jonesMLXLY wrote:though Autodesk would have solved this for 2020!!
They can't fix hardware or user issues.
Fixing your buggy mongrel blocks might help.
i had this problem with all files and all types of editing, does it all the time, even after changing across to 2020. I got the fix from a forum over a year ago, so seems that other get it too, not just localised to my machine!
thank you anyway, you posted on this forum in 2017 to do with this issue......guess you look at so many. people are still dealing with this issue 9 years on with no solution to the problem just lots of fixes, stand by my comment that AutoCAD has not fixed the bug in the system, guess not enough people experience it for it to be a priority, even their tech dept has not found a problem, even using a recommended AutoCAD graphics card!
You have a lot of people responding that have been using AutoCAD for a long time telling you they have never experienced or heard of your issue before. You also admitted that your blocks are not built well.
Have you even considered that you might have a set of circumstances that are causing this?
Why don't you share one of your files that are showing this behavior? One that is very bad. Someone can check your content to see if that is the culprit.
LOL yes............but it is inconvenient being out to the extents of a very large drawing some 10,000sqm in area, to have to zoom and find your place again, AutoCAD should fix the bug instead of me fixing it.
