Plot and Publish job error: did not plot
Message 1 of 9
I get an error every time I try to publish multiple sheets together:
Job: - Plotted with Errors(s)
Job ID: 7
Sheet set name:
Date and time started: 11/25/2019 2:04:36 PM
Date and time completed: 11/25/2019 2:06:32 PM
UserID: noa
Profile ID: <<Unnamed Profile>>
Total sheets: 4
Sheets plotted: 1
Number of errors: 3
Number of warnings: 0
Sheet: 515 - Error(s) Did Not Plot
File: .dwg
Category name:
Page setup:
Device name: _AutoCAD PDF (General Documentation).pc3 - plotted to file
Plot file path:
Paper size: Previous paper size (900.00 x 820.00 MM)
ERROR: Error
This happens on several files.
The first sheet plots and then all the rest don't with this error.
Any ideas?
Replies (8)
Message 2 of 9
pendean
Community Legend
Community Legend
Are you using the named pagesetup in each of those sheets?
Or are you replacing the pagesetups from a template file?
Or are you using the PDF option in PUBLISH command?
Message 3 of 9
I use the PDF option in the publish command
Message 4 of 9
pendean
Community Legend
Community Legend
Your LT year version as listed in ABOUT command is what...?
Message 5 of 9
Message 6 of 9
h_s_walker
Can you post your publish dialog box to show us what choices you're selecting
Howard Walker
Left Handed and Proud
Message 7 of 9
Message 8 of 9
pendean
Community Legend
Community Legend
Your 2017 is not up to date: go get and install those updates.
But first reinstall 2017, then remember to turn off background publishing, THEN run RECOVER to open all of your files to fix any errors (and save the files afterwards).
Let us know what you discover.
Message 9 of 9
h_s_walker
Do you choose a pagesetup for all the pages or do you choose just the first?
If you leave it as none does each individual layout have it's own pagesetup?
Howard Walker
