Doors (in an xref) are showing up in model space, but not in paper space. The layer is not frozen in the paper space viewport.
Any ideas?
Thank you.
Solved by pendean. Go to Solution.
The objects that are not showing up are doors. That layer is not frozen in the viewport.
I don't use AEC..... I did a 'list' of the object in the xref and that's what it said it was --- AEC_DOOR
What is a lot scale? The scale of this particular viewport is 1/32 = 1'-0"
Thank you.
wow - thank you for all of those tips....
I tried all of them, but they didn't work....
However, I will file those solutions over in my memory banks for possible future problem solving... lol
It is a small area and I will just copy some doors over into the drawing...
I probably should have just done that in the first place and saved a lot of time - LOL
Thanks again.
