AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Access Denied
2 REPLIES 2
306 Views, 2 Replies
Access Denied
I get the following error when trying to paste from the clipboard, only in 2005LT:
Access Denied
Error: CreateDirectory(C:\Docume~1\Admini~1\Locals~1\Temp\Adskcleanup.0001.Dir.0001)
This only appears when trying to paste after several successful attempts, so it looks like a file is becoming full or something. 2004LT doesn't have this problem. Any idea's?
TIA!
2 REPLIES 2
Quit LT, clear out that TEMP folder being referenced, try again. -- Dean Saadallah Add-on products for LT http://www.pendean.com/lt --
Hi, We have seen this error occur due to a conflict with either of these two third party applications: The "AtLast!" file management tool, or Npdor.exe, which is used as an online market research tool. Please check for the existence of either of these two applications. If you do have the AtLast! file management application, please follow-up with that publisher (www.filenotes.com) for details of their workaround to this problem. They have an updated release just recently made available (v3.2) which resolves the problem. Similarly, if you have npdor.exe installed, please remove it and reboot in order to run the AutoCAD LT 2005 successfully. Regards, Greg Suppes Autodesk, Inc. "NOBRKES" wrote in message news:16264705.1084805307430.JavaMail.jive@jiveforum1.autodesk.com... > I get the following error when trying to paste from the clipboard, only in 2005LT: > Access Denied > Error: CreateDirectory(C:\Docume~1\Admini~1\Locals~1\Temp\Adskcleanup.0001.Dir.0001 ) > > This only appears when trying to paste after several successful attempts, so it looks like a file is becoming full or something. 2004LT doesn't have this problem. Any idea's? > TIA!
Forma Design Contest
Technology Administrators
