We have seen this error occur due to a conflict with either of these two
third party applications: The "AtLast!" file management tool, or Npdor.exe,
which is used as an online market research tool. Please check for the
existence of either of these two applications.
If you do have the AtLast! file management application, please follow-up
with that publisher (www.filenotes.com) for details of their workaround to
this problem. They have an updated release just recently made available
(v3.2) which resolves the problem.
Similarly, if you have npdor.exe installed, please remove it and reboot in
order to run the AutoCAD LT 2005 successfully.
Greg Suppes
"NOBRKES" wrote in message
news:16264705.1084805307430.JavaMail.jive@jiveforum1.autodesk.com...
> I get the following error when trying to paste from the clipboard, only in
2005LT:
> Access Denied
> Error:
CreateDirectory(C:\Docume~1\Admini~1\Locals~1\Temp\Adskcleanup.0001.Dir.0001
> This only appears when trying to paste after several successful attempts,
so it looks like a file is becoming full or something. 2004LT doesn't have
this problem. Any idea's?
> TIA!
